Hi.
I am rebuilding a 6v6 pp stereo power amp for someone. It was a kit and he did it but not did it right. I have rebuilt it with a couple of changes
It is just a power amp now with 6sl7 as pi
I have been running it for a week seems ok
But I'm not happy if you turn it up sound just a little distorted
On testing with signal gen an scope sine wave is prefect.
I believe that the pi circuit needs a tweek
The circuit for pi I have used before a few years ago and it's ok. I should know I use the amp at home. Can't remember where I found it. On line
Variable bias 25ma per tube
Ht voltage 287v
Pin 2 -148v 100k
Pin 5 - 180v 100k
Pin 3 and 6 -1.6v
The nfb I'm using is from the original circuit 22k and 50pf cap connected to the 1.6k . The amp is definitely better without nfb switched on
Looking at other circuits they don't seem to use an cathode bypass cap across the 1.6k
Looking for feed back on any tweak. If any more info is required let me know
Many thanks
Mr a
Ht voltage 287v
Pin 2 -148v 100k
Pin 5 - 180v 100k
Pin 3 and 6 -1.6v
Many thanks
Mr a
