This is from my thread about op-amps that morphed into the MOSFET push-pull discussion. I figured I start a new thread that's on topic of the title.
I had to back burner the project for a bit. My computer bought the farm, though being 8 years old, it was time. But that had me occupied. Also, my plan is to build the cabinet in my Dad's workshop as he has about every type of wood working power tool Sears ever sold. Due to his age, he hasn't been able to work in the shop for several years, and it turns out most of the items in the shop need fixing up. Some have power cords that are dry rotted to where you can literally see the copper. I'm glad they were not left plugged in.
Anyway, as I'm making my back to this, what I have built on the breadboard is actually working quite well. It does need some dialing in and a bit of tweaking, but I don't think I'm that far from done.
One question I have on biasing. It was suggested to use a Vbe multiplier in place of the diodes, which would be resistors with a transistor. This might be a dumb question, but why could I not just use another resistor on it's own, possibly a variable resistor? As it sits now, the two resistors I have with the two diodes all form a voltage divider with the diodes providing a difference between the sources, which a resistor in their place should do the same.
Another question from observation - I'm currently powering this from my dual voltage power supply at 10V +/- with an 8Ω speaker. And it's actually a pretty good volume level at the speaker. So I connected a 4Ω speaker that I have, and the volume seems lower. But shouldn't that mean roughly twice the power and hence a louder volume?
