Hi Folks, I'm trying to add a parallel effects loop with mix control into a standalone preamp. It is for line level effects, recovery gain is not needed.
Seemed simple enough, but the circuit as-is is causing distortion/signal loss even with nothing in the loop.
Must be a loading issue? I'm having trouble following the impedances here. Each of the triangles are Mosfet buffers, output Z around 100 ohms.
Or if there's an entirely better way to implement this, I'm all ears.
Thanks for looking --
