Originally posted by Leo_Gnardo
View Post
loudspeaker equivalent circuit - representation of acoustic power
Originally posted by Malcolm Irving View PostNot easy to do in practice, but operating a speaker in a vacuum would be an interesting experiment because all the acoustic load would be eliminated.
Comparing the measured impedance curve in vacuum with that in air, we could see which resistive elements of the equivalent circuit model have been reduced.
Originally posted by glebert View PostWonder if you used front-to-front isobaric speaker configuration you can essentially get "half acoustic load" or something like that.. .
Yes, I think Orange used isobaric speakers in some bass cabs. The speaker facing the audience has most of the air load at its back cancelled by another speaker carrying the same signal. The two speakers are identical, co-axial and as close together as possible. I believe the main effect was that the low resonance dropped in frequency by about an octave (compared to a single speaker in the same cab).
Within physical limitations, you could put an identical speaker in front of the speaker under test as well as another behind it. This would almost eliminate the air loading at wavelengths which are relatively long in comparison to the gap between speakers.
This GOOGLE page about Acoustic Impedance Analog equivalence (electrical vs. mechanical) should be helpful:
https://en.wikipedia.org/wiki/Impedance_analogy
and, here is an older (1943) book for further reading:
http://www.tubebooks.org/Books/Atwoo...0Analogies.pdfLast edited by Old Tele man; 01-03-2019, 11:07 PM....and the Devil said: "...yes, but it's a DRY heat!"
Quote:
"Acoustical Impedance. - Acoustical impedance is the complex quotient of the pressure applied to the system by the resulting volume current. The unit is the acoustical ohm.
Acoustical Resistance. - Acoustical resistance is the real part of the acoustical impedance. This is the part responsible for the dissipation of energy. The unit is the acoustical ohm.
Acoustical Reactance. - Acoustical reactance is the imaginary part of the acoustical impedance. The unit is the acoustical ohm.
Inertance. - Inertance in an acoustical system is that coecient which, when multiplied by 271times the frequency, gives the positive imaginary part of the acoustical impedance. The unit is the gram per centimeter to the fourth power.
Acoustical Capacitance. - Acoustical capacitance in an acoustical sys*tem is that coecient which, when multiplied by 271times the frequency, is the reciprocal negative imaginary part of the acoustical impedance. The unit is the centimeter to the fifth power per dyne."
~ Dynamical Analogies. Harry F. Olson, E.E., PH.D. 1943
(good eye, Old Tele man)If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by Malcolm Irving View PostYes, I think Orange used isobaric speakers in some bass cabs. The speaker facing the audience has most of the air load at its back cancelled by another speaker carrying the same signal. The two speakers are identical, co-axial and as close together as possible. I believe the main effect was that the low resonance dropped in frequency by about an octave (compared to a single speaker in the same cab).
Within physical limitations, you could put an identical speaker in front of the speaker under test as well as another behind it. This would almost eliminate the air loading at wavelengths which are relatively long in comparison to the gap between speakers."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
