LTSpice and power measurements
  • LTSpice and power measurements
    Hi folks,
    i'm a bit stuck with the need of power determination in LTSpice.
    I am doing something like this:
    .meas tran Pw rms(V(out)*I(R1))
    .meas tran Pw_avg avg(V(out)*I(R1))
    The first expression seems to be "marketing director's RMS power" - values too large with limited physical meaning. Which has tricked my during the design of my Little Bea.R but i would guess this might also be the basis for "18W Marshall amps" and the like.
    Toward a more realistic determination i tried the 2nd statement yielding more plausible numbers in absolute value. Unfortunately, they are negative.
    How do i obtain realistic and trustable values, especially on G2 load?
    I don't know how to write it in LTspice but shouldn't the first expression be -
    Power = rms(V(out)) * rms(I(R1)) ?
      fails. Or i did not guess the syntax correctly.
        Yes, same here but it gives the right answer when I do it manually.
          And again - modeling something like the power on G2 of pentodes is important but estimating that power is hard to do manually.
            Maybe I misinterprete the power formula rms(V(out)*I(R1)), but power is not the rms value of the product V(t)*I(t) but the time average of V(t)*I(t).
            Time average is calculated by integrating the product V(t)*I(t) over an integer number of cycles and dividing the result by the integration time interval.
            Only in the special case of a (linear) resistor, where voltage and current are proportional and in-phase, power is given by
            P=Vrms*Irms.
              You mentioned the power output of the Marshall 18W so I simulated that.
              Did you see the other thread where we discussed pentode G2 power?
              I tried to measure it on my 18W at full power. The calculated power was 2.6W.
              It's the black trace on the plot below.
Name:	EL84 Screen Power.png
                P=Vrms*Irms.
                Yes, it worked in LTspice for the 18W amp's output power but is useless for G2 power.
                This could work. Run the sim then use the LTspice "Add Trace" function to plot the trace Ig2 * Vg2, select an integer number of cycles then press 'Control' + 'Click' to display average power.
                I think that's what bea wants.
                  Correct. That's why i called it "marketing value". My problem is actually that the 2nd approach which was the attempt to do the correct formulation, in some situations gives reasonable values which coincide in absolute value with what i would read from the screen (Veff^2/R) but with the wrong sign. Which clearly should not happen and furthermore is not generally applicable.
                    If R is the screen resistor and Veff its voltage drop, (Veff^2/R) gives its dissipation, but not screen dissipation. Because of the square involved, (Veff^2/R) must always be positive.
                    Screen voltage and current are not proportional nor in-phase. The screen to ground path does not behave like a resistor, so rms values of voltage and current cannot be used for calculation of screen dissipation.
                      All correct and not at all in contradiction to me. You can query for both current and voltage directly at the screen node.
                      Veff^2/R can be done at the final load resistance and hence be used to check for the correctness of the result. And if
                      gives a negative number it does not do what it is advertized, or better what i believe is advertized. It just seems to be some kind of sliding arithmetic mean of the product, which in that case is indeed always negative due to the choice of the zero potential in a way allowing NFB.
                        Seems there is some misunderstanding.
                        From this I concluded that you wanted to calculate screen dissipation from (Veff^2/R), which is not possible.
                        What is the context of this:
                        If you use avg(V(out)*I(R1)) for calculation of output power (assuming that R1 is the load resistor), the result will be negative, if either V or I is not defined properly (i.e. out of phase with each other by 180°), but the absolute value of the result will give the correct power.
                        Do we agree that screen=G2 and that screen dissipation and output power are not (directly) related?
                        I am confused.
                          Please see image below for an example on how to do power calc in LtSpice:
                            EL34 screen dissipation sim.
Name:	EL34 Screen dissipation.png
                              To output the G2 dissipation in Spice the syntax for example a 5ms interval is
                              .MEAS TRANS POWER G2 INTEG (v(S)*Ix(U1:Screen))/0.005
                              S is the screen grid node, U1 is the device under test.
