Super Saver Soldano Project
  • Super Saver Soldano Project
    Greetings fellow amp-builders,
    as a sort of delayed introduction to this community, I would like to show of my current amp project. It has been over a year that it has been waiting for completion, but it came together very nicely over the last couple of weekends. What I build is a souped-down version of the famous Soldano SLO-100, souped down because the high gain preamp is coupled to a power section of only 16W, sporting two PL84 tubes.
    The amp is basically build around two parts: A "Solton Craafty 30"
    Combo amplifier that I scored from eBay for 120€, and from which I
    only retained the chassis and the iron. The second major component is
    the PCB, which was designed by Joachim Müller, who probably build the
    nicest SLO-Clone in existence, and made a small production run of the
    PCBs which can be bough from www.tube-town.de. Other than that I only
    bought the pots and the tube sockets, everything else come from my scrap
    heap. The total cost is only around 250€ so far.
    The amp is working pretty well right now, without requiring any debugging, which is almost worrying since I tend to be really sloppy when building stuff. This is the first tube amp I have build so I was very impressed that it was working straight away, usually my projects burst in flames when I
    flip the switch the first time
    Most of the work actually went into the head shell and the front plate, which I cut from 4mm aluminium. I anodized it after cutting the slots and I tried dying it, but for some reason the dye would not stick, so it has to stay gray. The head shell is only a prototype really, since I want to make one from flamed maple when I get my woodworking skills up to par.
    Well, enjoy the pictures and dont hesitate if you have any questions.
    "A goat almost always blinks when hit on the head with a ball peen hammer"
    Tre cool How does it sound? Is that speaker cabinet what the combo chassis was originally in?
      Very nice!
      I don't have the patience to do woodwork. I have a furniture builder friend make my cabs for me.
      Here's a pic of one of my recent builds. This amp has a Plexi-ish front end with a Champish power amp. Sounds great.
      Last edited by Jag; 11-13-2007, 10:20 PM. Reason: Oooppps! Don't link LARGE pictures! :-)
        I finally got round to making a cab for it. I am trying a very special variation with "reverse loaded" drivers
        The cab in the above picture was - you guessed it - from the donor amp, and it was a cheap, nasty piece of particle board. I hate particle board, did I ever mention that? Nothing beats traditional woodworking!
        Now I just need to find a good speaker for it, since the one in there right now (that came with the amp) is f****** and the voice coil scratches on the magnet. I tried fixing it, but I guess some things you just can't do yourself. I am thinking of getting a neodymium speaker, as the cab is heavy enough as it is.
        Oh, one thing I noticed: When I put the back wall on the cab (With the speaker in the right way round), the volume drops to less than half, so I am guessing the power output drops to a tenth or so. Is it normal for closed cabs to be that much less efficient than open back cabs? Or did I do something wrong?
          Schematic
          Hello, which schematic did you use? I have the pcb boards from tube town, but can't find the right schematics.
            Nice. How did you cut those dovetail joints? I not crazy about the woodworking part of this stuff either....
              Joe Bee last posted over 8 years ago, so unless he has an email subscribe for this thread, we may not hear back at this point.
