I'm posting this as a query to see if anyone has seen this idea as a means of balancing an LTPI before. This forum audience has seen more amps than I'll likely ever see. I've looked around the web and in my Morgan book. I'm guessing it may have turned up in the hifi domain, but I have not found it. All my searches just find pointers to active current sources to help balance a PI. I have not seen this solution yet. The circuit is pretty simple...
It works by adding about 25% more of the NFB signal at the base of the tail than at the inverting input. That turns out to be just about right for the tail base to track the cathode voltage exactly, thereby making the tail an almost perfect current source. I've Spice'd this PI (in a Deluxe Reverb output stage) and it seems to work really well, especially given the added parts count of only 2 resistors. The outputs are damn near perfectly balanced with two 100K plate load resistors.
I don't really want to debate whether a balanced PI sounds good or violates some secret amp juju. This is just a design question. If you wanted to build a balanced PI, this seems a way to get one without resorting to active sources or changing load resistors. I realize the 82k/100k load resistors are the standard way to balance the outputs by compensating for tube current differences. This is an alternative that actually balances the tube currents. Has anyone seen or used this idea before? Are there any downsides to the circuit behavior that I've missed?
Given the way it works, it also seems to be a way to make a lower value tail resistor perform like a really high-impedance current source, so you can reduce the cathode elevation voltage and add headroom to the outputs without sacrificing balance.
