I have always been curious why old Sunns typically do the power supply in a way where there is a reservoir capacitor after the rectifier and this node is not used to power anything. Then they have a choke, then all power supply nodes come after the choke. So the choke has to handle all current that is drawn for the whole HV winding, BUT it is still not considered a "choke input filter, right? Because a capacitor still comes before the choke?
Most other amps you see are similar to the other image i attached. There is the rectifier, then reservoir cap which is the B+ node, then a choke, then screen supply node, etc.
So in one way it makes me wonder if the sunn style has a stiffer power supply because it has the extra power supply node, and in another way I wonder if the whole power supply sags more becasue of the DC resistance of the choke in series with everything. Which is it, or is there another reason entirely to do it this way? Does it possibly have something to do with a lot of Sunns having an ultralinear power amp style while most other amps are not ultralinear?
Thanks for any comments
