Hi All,
I recently bought a used recent-model (2016, I think) Bad Cat Hot Cat 15R. I can't find the actual schematic, but the Hot Cat 30 schematic floating around is, I guess, close enough for the preamp, at least. I'm confused by V1a's lack of a cathode resistor or cathode bypass cap (the "gain" control in the gain channel). . The plate resistor is 220k. What is the net audio/sonic/circuit effect of this?
I also find this amp to be too "over the top" in the gain channel, although it certainly can be easily tamed by more sedate preamp settings. I'm wondering if I could also tame this beast by some strategic tube changes (i.e., 12AY7 subs).
But mostly, I'd like to understand this type of preamp tube configuration on v1a and what it's intended effect is. Any suggestions on component changes to back the gain down in the Gain channel would be appreciated, though, if only for discussion.
Man, this thing has a gorgeous tone in the clean channel, btw. Wow!
Thanks in advance!
Fred G.
Thanks in advance!
Fred G.
