In this following power supply circuit, I am not sure why the filter caps are stacked as they are. I am replacing all the filter caps, and have questions about what ratings I can use. The schematic shows 220uF/350v reservoir caps, but what the originals in the amp are 220uF/450v. Am I correct that the total capacitance for the two is 110uF, and that each sees an equal voltage amounting to 1/2 of the B+? What would be the better choice for replacements, 220uF/385v or 250uF/500v? JJ offers both at CED. Same question for the 220/350v at node B, lower voltage rating or higher capacitance? The dual 50uF replacement is rated 450v.
And what about the 32/16uF on nodes D and E, would there be any trouble with making it a dual 32/450v?
https://hiwatt.org/Schematics/DR504OL.gif
