Originally posted by catalin gramada
View Post
Paraphase inverter question
Originally posted by vintagekiki View PostRipple has nothing to do with the (para) phase inverter.
Ripple is about 100 mV / 50Hz, and the amplifier is without any signal from the generator.
Don't you think about ground loop?
EDIT 190909
Just remember the experience from the studio when the amplifier connects to the processor and puts it all together on the mixer.
All devices are earthed via the power cord.
Silence in space only when all earthing is at one point."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostOk, I tied the inverter back to power grids and this is what I get in differential mode:
This is with 47nF interstage
[ATTACH=CONFIG]55131[/ATTACH]
This is with 470nF interstage
[ATTACH=CONFIG]55132[/ATTACH]
To be honest I don't see any difference
Last edited by catalin gramada; 09-09-2019, 01:04 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
By interstage do you mean the cap connected to the virtual earth triode's grid? When I did the sim that one didn't have much effect. Try increasing the value of the caps to the power tube grids and measure at the grids.- Own Opinions Only -
Originally posted by catalin gramada View Post[ATTACH=CONFIG]55104[/ATTACH]
Tip.
In order to do custom any amplifier, you must first bring in 100% mint condition.It's All Over Now
Originally posted by Helmholtz View PostSeems I misinterpreted your sim results. I thought you had increased the second triode's grid cap. Having problems to see why increasing the power tubes' coupling caps would change phase difference in a symmetrical arrangement.
First plot 47n, second plot 470n.
I see a lot of pictures from the oscilloscope, various numeric values from the screen, who it mean nothing.
We just don't know what we want with a bunch of data.
I am afraid that we will stray because proposals and results do not indicate constructive debate.
Let's go back to the beginning
https://music-electronics-forum.com/showthread.php?t=49645&p=537990&viewfull=1#post537990
and to define what we want from thread.It's All Over Now
