Hi Guys,
I am looking for some advice, so I (hopefully) only have to do this once.
The attached circuit shows a 4 stage preamp that uses 3 stages for Clean and adds the 2nd stage (V2B) for Drive.
The circuit is shown in Drive mode and when switched to Clean, Relay 1A enables the Volume Pot and Relay 1B enables a full Bypass of the (Drive) 2nd stage.
Would you guys advise grounding the 2nd stage (V2B) output, as shown, to remove any possibility of signal or noise coming from V2B entering the grid of V1B; or will the Clean Bypass be sufficient to ensure uncorrupted Clean sound?
Modifying the PCB traces and installing wiring to enable Relay 2 to ground V2B output is a PITA job, but if it is advisable I will do it, rather than have the Clean sound compromised.
All advice, opinions, comments, gratefully received.
Thanks, in advance.
Thanks, in advance.
