Two of my power txf I had made for a moderately high gain circuit also have 5V/6A taps. I had these included because for whatever reason I love the sound I get when using tube rectifiers. I assume it is nothing more than the lower voltage because of the tube's vdrop. I suppose I could have had a lower secondary txf made, but here we are nonetheless.
One txf offers 360-0-360 on the secondaries and the other has 345-0-345.
My target VDC is 480 to 500. With ss rectifiers I get 500 to 515 VDC (using the 360-0-360 - have not used the other yet) depending on time of day. Previously I have used 2x 5U4GBs and arrived to a DC voltage of 486.
I was looking at old Marshall amps on Amp Archives... I have only seen (in photo of course) one or two other instances, in my various usage of the internets, a Marshall 1987 with a tube rectifier. I suppose some JTM50/JMP 1987 transition thing. But today I saw a 100 watt Superlead (likely also a JTM45/100 transition amp) with a single GZ34, no ss rectification whatsoever.
So I started to poke around various datasheets and I am hoping to gain some clarification.
Starting with a 5U4GB, Sovtek's datasheet (linked HERE for convenience) states:
Full Wave Rectifier - Capacitor Input Filter
AC Plate Supply Voltage (Each Plate RMS) - 450V
DC Output Current - 275mA
DC Output Voltage at Filter Input - 460V
And Sovtek's GZ34 (linked HERE for convenience) :
AC Plate Supply Voltage (Each Plate RMS) - 550V
DC Output Current - 160mA
DC Output Voltage at Filter Input - 640V
Here is where the clarification is needed... Reading these datasheets makes me wonder if I could run a single GZ34 and get the needed 485+ DV volts to power the amp rather than 2x 5U4GB. And perhaps I am too close to max anyway... so, yea, I am looking for a little knowledge from those of you with the experience to back this up, as I have NONE.
I do realize though that the 5U4GB vdrop is much greater than the GZ34.
Thank you, as usual, for your wizzzzdom!
