Absolutely! "Opening" the OT output while signal is applied is akin to "automotive breaker points 'opening' on older ignition systems," i.e.: reflecting a VERY high voltage...back into the OT rather than to a spark plug.
A 10-times-Z, non-inductive, "swamping" resistor in parallel with each amp's OTs winding input to switching circuit (not the speaker output) should mitigate this problem.
