An underrated OT is likely to cause ugly saturation distortion, limit bass transfer and reduce available output power. When saturation occurs OT primary current strongly increases which may shorten tube and transformer life. In fact during saturation the OT primary impedance drops by a factor 10 or more leaving only the DCR.
As long as there is no saturation, the tubes don't care if the OT is underrated. This means that they will produce the same primary power with any OT having the same primary impedance. But an undersized OT can have power losses of more than 5W. So available output will be reduced by the same amount. The power loss in the OT heats up its thin primary wire and may cause shorted turns.
Without knowing your circuit and full power plate and screen voltages, it is not possible to predict the power your tubes are producing.
But I would at least use a 35W rated OT.
