Hi all,
I'm going down the endless tweaking wormhole on a design. I thought the amp was sound a little flat with all tone controls set at noon, and decided to boost treble a bit to make things sound more lively. A convenient approach is adding a bypass cap to the cathode of the triode gain stage that precedes the tone stack. That gave the desired effect but now the bass control seems to behave more like a gain knob than an EQ knob. The gain stage is V2a below:
I put a large .1uF orange drop in as the cathode bypass cap on V2a. Going off of the cathode bypass calculator on ampbooks.com, I wanted to place the gain boost more towards the treble frequencies at 1kHz+. My guess is that I've affected the way that the tone stack is being loaded by the preceding gain stage but I'm not entirely sure.
Any ideas on what's going on here?
Edit: Took out the cathode resistor bypass cap, and this bass control still sounds more like a volume knob to my ears. Maybe that's how Fender tone stacks are? I might try something like a baxandall next time around.
