MEF members...
I came across a non-functioning Heathkit IG-82 signal generator - schematic. The case seems like it is usable for an upcoming project I want to undertake. That will be a different thread some day.
This unit has a Power Transformer with the # 10976526. It also has 54-59.
Input Wires
Red Output Wires - 125 vac, no centertap, unloaded
Green Wires - 7.0 vac, no centertap, unloaded
The unit uses the following tubes:
6CL6, qty 2, 650ma x 2 = 1.2 amps
6AW8A, qty 1, 600ma
6CB6, qty 1, 300ma
12AT7, qty 1, 300ma
(I assume the specs I found are relatively accurate for a given tube)...
So I pull out the abacus, flip the beads, and it looks like the transformer is supplying ~ 2.5 amps on the heater winding.
If nothing else, the transformer would serve as a standalone heater supply? The only thing needed might be a couple 100 ohms resistors to ground?
I found this Heathkit at a local electronics surplus place ($10). I felt like Mike and Frankie doing some digging on American Pickers!!
Input Wires
6AW8A, qty 1, 600ma
6CB6, qty 1, 300ma
12AT7, qty 1, 300ma
