Chassis is steel; guessing anty sheild I install should also be steel & not aluminum? Or at least magnetic.
Looking for a Noise Theory...
A few random observations...
Setting it up to squeal but then setting the guitar across the room (maybe 10' away) & no squeal. I feel like it's ground-related, though, as I can get it to screech by grabbing the tube & then if I grab the strings/controls/bridge it stops. I'm picking up a loud buzz too, mainly through the bridge pickup, that also ceases when I grab the strings. So I still feel like there's something there... And why the pickup transmits more noise when I get my hands near it or grab the bobbin is kinda annoying.
I'm gonna use shielded cable for the Cut control runs; as for the rest of the amp, it's tight & there aren't really any long signal runs due to the tube layout. There's not really enough room to get any shielded wire in there.
Thanks for all the ideas, & some of these I'll have to file for "future use" on build #5. Otherwise, it's clean up my mod-mess & finish the cosmetics for this guy. And explore my guitar wiring & probe my grounds.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
BTW, grabbing the other power tube should not produce squeal as its plate voltage is out of phase.Last edited by Helmholtz; 01-15-2020, 10:21 PM.- Own Opinions Only -
Ah, that makes sense.
I stuck a bit of insulation in the input jack to defeat the shorting feature, that enabled noise. I also both used shielded wire for my Cut runs, then used regular with a shield of copper tape around it. No success. Put a grounded steel shield between pickup & power tubes, no luck.
I may pull out my Bassman & compare some things, using same speaker. Kinda wish I'd bought a scope way back when I hd money instead of buying more amps...
Justin."Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Update.
So I dug my Jet with the crappy Celestion out of the closet & rigged it up with a series of jumper wires & such. Holy $#!+ this amp was brite! After looking at about 4 different tone stacks, and 18 working hours later, I finally got pissed off enough to just make the damn thing a straight-up Fender 50W Normal channel w. a Mid control & permanently set Cut across the PI.
I'll just say I have a useful tone stack with lots of spread & this little tird gets loud AF. Tweaked a few caps but otherwise, yeah. That was easy... Three years later. Oh well, at least I'll get a decent amount of money on this one. If I average it out over the 3 years, I think I'm up to maybe $1.50/hour.
But the damn thing WORKS.
Originally posted by Justin Thomas View Post...I'll get a decent amount of money on this one. If I average it out over the 3 years, I think I'm up to maybe $1.50/hour."Take two placebos, works twice as well." Enzo
Originally posted by Mick Bailey View PostI've had a few amps for repair where when the shielded back panel is removed they exhibit guitar-specific electrical feedback. One Fender in particular played like a theremin with hand proximity to the output tubes, but only with the volume turned down. Full up or at zero, no noise. With a different guitar, no noise at all.
I also has a standalone tube reverb that did this and I kept coming back to that for ages before finding it was the recovery tube coupling cap at fault. Why that only fed back with certain guitars is a mystery.
Do you have foil screening in the enclosure or back panel?
Usually I just get some feedback and harmonics,and run up the repeats and level on my digital delay, and use my whammy bar to warp the sound further.
This would be a step up, no Joke !" Things change, not always for the better. " - Leo_Gnardo
Justin
I've run into the same amp tone tuning problems as you before, and I've only just kicked the habit of tuning my project amps with a single Jensen test speaker. I always have to go back and change something later on when I match the amp with a much bigger "real" cabinet that has darker speakers. The single 12" Jensen C12Q on my bench is convenient as it's in a small cabinet with a small footprint, and not too loud for testing, but it also is a bit too bright for a rock amp. So I stopped being a bit lazy, and now hookup the project amp to a Well worn Twin Celestion cabinet, before I consider the tone changes done.
Good Luck with that new Beast Justin !" Things change, not always for the better. " - Leo_Gnardo
