Using Jfets for switching in tube amps - high voltage concerns
I doubt it as the current is limited by the 100K resistor. In addition the voltage falls slowly and the capacitor will greatly suppress that ( i = C * d(v)/d(t) ).
Of greater concern is that FETs are suited to small signal amplitudes of just a few volts. You can tens out of tube stage.Experience is something you get, just after you really needed it.
100k limits current, but before tube conducts, full B+ voltage is at the plate. But the cap downstream end at the JFET also sees the volume pot. That serves to keep the cap grounded and so the voltage never comes through anyway.
But you are right about signal. What is the JFEt good for? Maybe 25-30v?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Mick Bailey View PostWhy not relocate the FET to the grid?Logic is an organized way of going wrong with confidence
Originally posted by nickb View PostI doubt it as the current is limited by the 100K resistor. In addition the voltage falls slowly and the capacitor will greatly suppress that ( i = C * d(v)/d(t) ).
Of greater concern is that FETs are suited to small signal amplitudes of just a few volts. You can tens out of tube stage.Originally posted by Enzo View Post100k limits current, but before tube conducts, full B+ voltage is at the plate. But the cap downstream end at the JFET also sees the volume pot. That serves to keep the cap grounded and so the voltage never comes through anyway.
Was just concerned about the the DC reaching the fet during the charging time. I’m not sure how the pot being grounded keeps the voltage from coming through before the cap charges. Could you explain that a little more?
Also would adding back to back zeners be cheap insurance to block any transients from coming through? I was already going to add some to limit voltage to the fet just in case.
Thanks!
Originally posted by Gaz View PostAlso would adding back to back zeners be cheap insurance to block any transients from coming through? I was already going to add some to limit voltage to the fet just in case.
Thanks!“If you have integrity, nothing else matters. If you don't have integrity, nothing else matters.”
-Alan K. Simpson, U.S. Senator, Wyoming, 1979-97
Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
https://sites.google.com/site/stringsandfrets/
Originally posted by uneumann View PostSure - zeners would help, but the transient coming through the cap is potentially full B+ voltage. Yes, current is limited, but voltage can fry semis at low currents - as with static zaps. There are options that seems better and safer. The DN3545 is a mosfet with 10 ohm on resistance and rated at 450 volts. Or how about solid-state relays - they're rated at 300-400V. I suspect Jfets are attractive because they're cheaper. But if you really want to be sure something is safe and reliable, maybe cheaper isn't the only criteria to consider.
I'm copying this Peavey circuit like below (also here is the full JSX schematic it's from, for example.)
They use this circuit in countless amps, but just noticed this one they actually use it after the blocking cap. They do use zeners (I don't know if they are to limit signal voltage or DC start-up voltage like I am worried about). There is 100K resistors in series as well, but I don't know if those are relevant to the jfet mute circuit or not...
Originally posted by Gaz View Post... I'm just super green when it comes to fet and Si in general, so any advice would be appreciated. ... They use this circuit in countless amps, but just noticed this one they actually use it after the blocking cap. They do use zeners (I don't know if they are to limit signal voltage or DC start-up voltage like I am worried about). There is 100K resistors in series as well, but I don't know if those are relevant to the jfet mute circuit or not...
You could consider this an "opportunity" to do some reading and get familiar with solid-state basics. JFETs and mosfets like the LND150 operate in ways that are similar to tubes so the leap is not hard.
That said, for a new design, you may want to look into solid state relays - like the AQY210EH series of parts. They are far more forgiving and simpler to use (IMO) since the control and relay signals are completely independent (they are optically coupled) and power transients are less of a concern when the parts are rated at 350v or higher.“If you have integrity, nothing else matters. If you don't have integrity, nothing else matters.”
Not that zener protection isn't a bad idea, but it just might be overkill.Experience is something you get, just after you really needed it.
Originally posted by uneumann View PostThese are tricky circuits to just copy/paste into a new amp - You have to view the FET, the signal levels being muted, the control signal to the FET all together as a system. In particular, the control signal has to be properly created at power up and power down to ensure that the FET is "on" so the power transients don't damage it. It's more complex that a simple "do this" and it will work.
Thanks!
Originally posted by Gregg View PostA 300-600V DIP4 SSR will do the job. It has a DCR of ~50 Ohms when on which is the same like J175. You can also put some back to back zeners for extra insurance.
Originally posted by nickb View PostI don't see this for realistic applications unless you are talking about fault conditions. This application would be in the preamp. The supplies will be filtered by something like a 22uf and 10k resistor making the time constant about 0.5 seconds and the voltage say 400V. The current through the FET will be limited by the 47nf cap to something like i = 47nF * 400/0.5 ~= 40uA. I can't imagine such a small current could cause damage to the JFET.
Thanks again
