A friend of mine with a BF Super Reverb was asking me about the Vibrato Channel of his amp because he doesn't like it as much as the Normal Channel. As far as I can tell, there's nothing wrong with it.
Since then, I've tested a few AB763 Vibrato Channels with a square wave, and though I can tweak the Normal Channel tone controls for relatively flat response, I can't dial in flat response on the Vibrato Channel. There always appears to be some treble boost on the Vibrato Channel, a spike at the front of the square wave. It's not ringing, but it's not flat.
By reading the circuit, you can see why it's not flat. I was just hoping someone else has seen the same thing to confirm my result -- that the AB763 Vibrato Channel is a lot more "colored" than the Normal Channel.
