I've been slowly working on a bit of a basket-case Magnatone M15A, so I've become very familiar with the circuit.
It uses a 2 x 7189A push-pull output stage with a -19V fixed bias supply, but instead of having their cathodes connected to ground, the pair of 7189As shares a single 100Ω unbypassed cathode resistor.
![Click image for larger version
Name: M15A output stage.jpg
I read another discussion on this site where it was pointed out that this bias arrangement would introduce some compression. I can see that as the output stage gets pushed beyond Class A, the unbypassed 100Ω resistor becomes a negative feedback source, limiting output by allowing the cathode voltage to rise.
Is hybrid bias used in guitar amps like the Magnatone primarily as a dynamic voicing trick, or are there other reasons for doing it? It's not done very often. (And I'm aware of Fender's brief flirtation with it.)
Perhaps to ask the question another way, why not just have a cathode-biased output stage with an unbypassed cathode resistor? I have seen that in some old Premier amps.
