OK, time for me to go to school, as I've only learned informally and have big holes in my knowledge of electronics.
If two voltages are coupled together, how does the voltage change / react ? I have a Hi-Fi amp that runs the power tube screens from two voltage sources, one is around 290vdc, the other around 340vdc. Not sure what is going on there. The schematic I have does not show this, so I am inserting a pic of the same EL84 hi-fi amp currently for sale on Ebay. If you look closely at the bottom right EL84 socket (there are 4 of them in this stereo amplifier), you will see a large 640 ohm cement resistor connected to the screen from a node coming from a high voltage. But there is also an Orange colored wire that goes straight to another cap in the can capacitor. That connection is a lower voltage.
Can anyone explain why this is setup that way ? How would the two different voltages interact ? More voltage stability ? Less ripple ? How about current ? Not sure of the design or the reasons why.
Thanks for any help !
