Hi all,
I'm trying my hand at translating a turret board design to a PCB. The goal is to reduce my build time as much as possible without sacrificing much in terms of reliability. For now I'm just going to have the preamp and the power/bias supplies on the board. The power amp construction is going to remain turret board w/ twisted pair heater wires.
I've tried to follow the same layout and lead dress principles for the most part, but am stuck at how to handle grounding. I usually follow some sort of star ground scheme in which the signal grounds relating to each power supply node are fed to their corresponding filter cap. Then each filter cap is grounded to the same point on the chassis with its own wire. What do you guys recommend in terms of grounding scheme? Here's my rough sketch so far:
![Click image for larger version
Name: Screen Shot 2020-05-25 at 2.51.47 PM.png
Name: Screen Shot 2020-05-25 at 2.54.01 PM.png
I also have an unused 5V heater supply on my PT secondary that I'd like to use for DC heaters. I'm thinking a rectifier bridge with a low forward loss might get me close to 6.3VDC and save me the headache of having to carefully route/wire the heaters on the preamp/PI tubes.
Any insight is appreciated, thanks!
