I have a 1x10", 2xEL84 and 2xECC83, Gibson GA15 (Trace Elliot Velocette in different clothing). It runs the plates at too high of a voltage so in order to get any decent current you have to over-dissipate the power tubes (stock it was @ ~17W per tube). If you could choose any plate voltage for this amp...what would it be?
Also, this amp has a slight metallic sort of 'rattle' (sort of ringing...but not really) but it's not the speaker or the cab, it's actually coming from the amp. It rides on top of notes, mostly noticable on lower notes. It happens even at lowish volumes, regardless of cabinet. Could it be the OT? It's always done it (it's pretty subtle but you guys know how it is once you 'zero in' on a noise) and I've done some extensive modding since then, no change.
