is it true that when reading the printing on the cap from left to right, you ground the right side? or that side goes to the tube pins?. this is from vacuum tube valley........
Capacitor Installation Tips: Remember to connect the inner foil side facing the output. In coupling caps, this means connecting the inner foil to the grid of the output tube and the outer foil to the plate of the driver tube. On some caps, the color of the wire indicates the inner foil side, on some the inner foil is marked and on others it is typically the right side of the cap when reading the value. On older caps, the outer foil is indicated by a band around the cap.
