I have a couple of 6ba6 remote-cutoff pentodes and naturally I wondered how they would sound. Seems like free compression and silly amounts of sustain are possible with these things.
A few issues come to mind. First is that they would sound "interesting" in the way that my mom finds Frank Zappa "interesting." So I would prefer to run it in parallel with a more conventional circuit and mix the two somewhere downstream.
Second, the compression is asymmetric. I think that would lead to 2nd harmonics which might be nice. But I am leaning toward using two of them in a PI configuration (Quad did this with a pair of EF86 in a see-saw thing which looks like fun.) If I do that, I will wind up with a diff pair. Since I would like to attenuate the output I will either have to use a gang pot and feed to opposite ends of the real PI (or even post PI) or I can remix the diff pair and stick it back wherever I want.
I would rather remix the pair before attenuation but I have no idea how to do this. Could I feed one end to the grid of a concertina and the other to it's cathode and then take the output from only the plate?
Third, I have been assuming that the remixing of the pairs would reduce the compression by half, but my brain started hurting, so my assumption may be wrong. If the mix eliminates the compression altogether, I will have to run the PI/compressor in Class AB . . . where's my aspirin . . .
I expect that lots of people have considered this, so is there a giant red flag that my beginner mind is missing?
Oh, I'm building a head in an apartment, so microphonics won't be much of an issue.
