I connected an EZ81's 6.3v heaters and the CT secondary's outside leads and read 242VDC on pin 3.
...no load.
Seems funny because the PT's ac at secondary is 265-0-265.
So far I just have the PS section before any resistors or caps wired.
IEC: I and C to the two PT primary leads, E to ground lug on chassis.
Secondary HV to pins 1 and 7, CT to ground/chassis.
Secondary has two 6.3v outputs, I chose the yellow one with the long enough wires, the other is green wires.
With this large PT I'm 1/2 hoping to attain very small volume output along the lines of 2watts or so, then do something for the preamp.
Simple output tube driver seems in order for this, so that perhaps it will be compatible with added gain stages via tube or other for more or less preamp.
...no load.
