Standby for Valve Jr. ?
  • Standby for Valve Jr. ?
    I put in an AC switch just because I wanted one and see that on the front of the amp in pictures...
    But...if I were to reduce volume to 0 while amp is warming up every time, is there any advantage to having a bypass switch?
    For a tiny amp like that I can't see any reason to bother with a standby switch. For that matter, I probably wouldn't bother turning the knobs down either.
      I put on in on mine. I haven't had it long enough, or use it enough to notice the difference, bt I still like having it.
