Strange new vibrato circuit in DR Reissue
  • #46
    Thanks Steve, I also swapped the lousy filter caps for some F&Ts, which reduced noise and hum quite a bit. The original first filter stage with 220uF/100V(C31) in series with 47uF/500V(C32) plus 100K/470K bleeders is quite weird. Using two 100µf/350V caps in series for a value of 50µf total with two 220K bleeders seems to me much better.
    • #47
      Is there a schematic for this version of the amp?
      Is there a reason to remove the grid stoppers- are the grid stoppers causing a problem, or is it just a nostalgia thing?
      • #48
        Originally posted by Steve A. View Post
        I took the liberty of converting your post into a PDF file that I attached here so that people here can download it. Let me know if there are any edits that you would like.
        Ok, Steve. Your page is great.
        Thank you!
        • #49
          Thank You!
          Here is a summary of the mods on my 68 Custom Deluxe Reverb:
          All dB values was measured with an iPhone 6 running Audio tools SPL Pro, placed on top of the reverb tank (A Weigthed).
          Problem 2 and 3 measured with all controls set down to 1.
          Problem 1: Terrible hum when reverb is turned up.
          Solution: Turned the reverb tank 180 degrees. The output side must be at the right, away from the transformers (seen from the back).
          Result:
          Clearer reverb with reduced noise.
          At max reverb, amp noise is reduced by 5.5 dB!
          Problem 2: Lots of noise when tremolo intensity is turned up.
          From min to max intensity the noise level is raised by 11 dB!
          Solution: Removed the ROHS tremolo circuit. Installed an optocoupler from TAD (FVIB Vibrato LDR for Fender).
          Result:
          No added noise at max intensity. Tremolo good.
          Amp noise reduced with 2 dB.
          Problem 3: Still some noise.
          Solution: Removed the seven 10K grid resistors from V1,V2, V4 (pin 2 and 7) and V3 pin 7.
          Result:
          Amp noise reduced with 4.5 dB!
          Total amp noise reduction after the ROHS tremolo and grid resistors removal is 6.5 dB!
          Extra mod. 65/68 feedback Switch.
          Replaced the never used ext speaker jack with a switch, who adds one 1.8K resistor in parallel with the 1.5K feedback resistor.
          In 65 setting the amp noise is reduced with 1dB, and the amp is more tight/clean.
          I prefer the 68 sound
          Bias current 27 mA, not changed.
          Regards.
