I'm in the process of building a pair of identical blackface-style amps. I have a pair of PT's and OT's that are approximately the size, ratios and voltages of a Blackface Princeton. I want to build some small simple little amps that I can use in place of some of my larger equipment that's currently serving this purpose. I want the minimum of components and weight while still achieving a Blackface sound. The reverb needn't be a surf verb sound (not too much drive) but I'd like to have a decent reverb volume.
I have two questions- one revolves around reverb drive and blending, the other around phase inverter design. I intend to use three dual triodes, two 6v6's and a 5 volt tube rectifier. My chassis (already built) are 11.5" x 5" by 1.5" and I'd prefer to use them if I can so simpler is better! If this fails I'll upgrade to a 13" hammond enclosure but I want to keep it as small as possible.
I want to simplify the reverb to reduce my tube count and eliminate the 3.3M resistor- I don't know why but it always bugged me! I am planning to use a blackface preamp followed by some sort of resistive mixer into the phase inverter. I'll drive the reverb from the standard 500pf cap into a 1meg pot to allow verb drive adjustment. I am still considering using a mosfet verb driver. I would like to use a 12DW7 low-gain side as the reverb driver. I was considering using it like a Magnatone or Ampeg with a largish plate cap driving a high-impedance reverb tank. I have a few tanks laying around the should work well for this.
I'm most concerned with reverb return. I was thinking that I could use a 12ax7 in the LTPI for a little extra gain after reverb recovery. The single triode (12ax7 or 12dw7) I use for verb recovery will be setup for highest possible gain. I'm considering a simple 1M linear pot panning between the output of the preamp and reverb recovery stage, possibly with extra series resistance as needed to make the control usable. I don't need to turn off verb with a knob because I'll mute it with a remote footswitch activating a relay or LDR on the send or return circuit. I'm hoping to have more than enough gain for pretty sounding verb while retaining a tone similar to the "normal" channel of a BF amp but with a little less gain.
Of course...this assumes I use a LTPI. Can anyone out there convince me that the Princeton circuit would be a better starting point? What would be the clean volume difference of the two? My PT and OT are only good for about 15 watts, similar to a BF Princeton.
Thanks, hope everyone is enjoying their Satuday night!
jamie
jamie
