I've been googling info on L-Pads because I'm going to do a simple experiment essentially just sticking an L-Pad at the output of my Marshall Power Brake to lower the volume further and to see how good (or not good) it sounds that way. One of the bits of info/diagrams I encountered is this (simple L-Pad design for low wattage amp) :
http://blueguitar.org/new/schem/misc_mod/power_sk.jpg
...and for the shunt R, instead of a shunt R only, there is a rheostat (which of course here is to make the output adjustable). My question, is why is there both a shunt R and a rheostat, instead of just a 4 ohm rheostat(4.7 and 25ohms in parallel is 3.96ohms)? Is there some kind of advantage in using a shunt R together with a rheostat? In terms of current handling, my understanding is that a lower resistance value for a given wattage rheostat can handle more current (from looking at the ohmite rheostat datasheet plus if you look at actual rheostats you can see that very low R units have quite a thick ribbon-like physical shape for the resistive element versus the higher R units which have more of a wire), so from that perspective use of a rheostat only would seem to be more advantageous. Perhaps I'm overthinking this and the designer just used what he/she had? Or maybe it's an economical design (meant to be) since it uses a relatively inexpensive 3 watt rheostat?
