I'm not sure either
. I think I'm trying to calculate the maximum voltage swing across the plate load.
According to my multimeter, my laptop is putting out 270mVAC. In the first gain stage I measure a drop of 102VDC across the 100K plate load. From the plate load to ground I measure about 17VAC pk to pk which gives the stage a gain of around 60.
B+ for V1a is 370VDC. That means the maximum voltage swing will be from 285VDC to 251VDC. As tbyranh said earlier, a boost pedal might have a gain of 10 = 2.7VAC input which means the signal swing could be about
370VDC to 106VDC, worst case scenario.
So the switch/vactrol would have to rated for 264VDC.
Does this sound about right?
![Big Grin](https://music-electronics-forum.com/core/images/smilies/biggrin.png)
