Class A SE vs Class A PP?
    Originally posted by kldguitar View Post
    Who have drawing of Class A pp and SE, Class se is easy understand.but PP is difficult to understand only by words. Are the two tube parallel, use two tube amp current?But it not pull and push
    Well, in my opinion ... yes and no.
    I think as far as DC goes, yes, the two power tubes are in parallel in class A PP or class AB PP, for that matter any class of push pull.
    But, the AC current part, which is generated in the power tubes and output transformer, is not in parallel... because the phase inverter section ahead of the two PP power tubes drives them with AC, one at a time, 180 degrees (or close to it) but out of phase which each other.
    You can make a class A SE amp with many parallel power tubes, sharing a SE output transformer with no usable center tap.
    Then all power tubes are in parallel with respect to DC and AC current.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
      I can't recall, it seems a few are marketed as class A. It is a matter of bias.
      In marketing, "Class A" means "cathode bias and no negative feedback". I guess "Class A until you turn the volume up really loud" wasn't quite as catchy...
        A class AB amp stage will be operating in class A until the signal level gets large enough to turn one tube then the other off for portions of the waveform. Class A conducts all the time, class B half the wave, the remainder in cutoff. Class AB is in between, so whatever the portion of the wave in excess of 50% it takes to turn off one side is hte portion that is running in class A. SO whatever tonal shift might occur at that threshold is the answer.
        Yes It Is !! A push/pull gain stage ; in an amplifier with a "varying" level input signal, like a guitar amp ; will be operating in Class A until the drive signal gets large enough to shut down the power tube on the negative swing of the input signal. Since the VOX amps work in this manner, perhaps there in lies the answer.
        It is just that, push/pull output transformers are smaller and can handle more power than there SE counterparts. As long as both sides of the primary coil are pretty evenly balanced dc wise, anything else is fair game...including tossing out the PI...
        -g
        ______________________________________
        Gary Moore
        Moore Amplifiication
        mooreamps@hotmail.com
          This analysis isn't meaningful, as even regular class B semiconductor amps are biassed just into conduction, just a few mA sufficient to get rid of the crossover gap. On this basis would they be class A as long as the power was kept below 0.1 watt?
          The class of amplifier operation is only relevent / meaningful when applied to the maximum sine wave that the amp can put out ie max rms power before clipping.
          Aiken explains this very well - Peter
            OK, get pedantic. The point was to try and dispell the idea that Class A is some magic thing with night and day differences.
            In your class B solid state example, we would call it a class B amplifier, of course. Personally I would differentiate between what we label the amp as, and the class of operation at any given set of operating parameters. So as long as everyone knew the context of the remark, we could say that it operates in class A for that special condition. WOUld it be useful information? No, of course not.
            Something analogous - the difference between being a baseball player and playing baseball. If you pitch a ball to me and I swing a bat at it, we are playing baseball. I would not legitimately call us baseball players, but we would indeed be playing baseball.
            But in the case of a tube amp and someone wanting to know what the different classes sounded like, we bent your rules to show that an amp will sound like class A until you turn it up. When you turn it up enough to cross that threshold where alternate half cycles are not comlpete, then the sound of class AB operation results. This is served up only to offer a means to tell how much diference in sound there would be and would not be. To that extent I find meaning in the discussion.
              'There is a very real difference in tone and operating conditions between a true class A 10W amplifier running at say, 1W, and a 10W class AB amplifier running at 1W. Same output level, same overall power level, *but* a different class of operation, different amount of distortion, different efficiency, *and* a different tone, even though neither one of them is in cutoff for any portion of the output cycle at that low level. This is due to the bias point differences and load line differences. The differences become even more apparent when the amplifiers are run at their full undistorted output power. The true class A amplifier will have no crossover distortion, while the class AB amplifier will. The average plate current for the true class A amplifier will not change, or will change very little, from idle to full output power, while the average plate current in a class AB amplifier will increase dramatically. This will lead to "sag" in the power supply that doesn't exist in the true class A amplifier, which again results in a tonal change.'
              http://www.aikenamps.com/ClassA.htm
