i built a 18 watt and the 4 stage preamp is cascaded with 2 volumes and a master and has a good bit of gain. I have a bit of a issue with the stages in V1 tho. It's a bit bright and buzzy when the first volume is cranked. as it's turned down it goes away at about 12:00, but then of course so does the gain. I don't mind losing some gain, but not quite that much. So I thought maybe the cathode and plate resistors might need to be tweaked so that the tube is biased correctly, but i know nothing about doing this on a 12ax7. The plate is 100k and the cathode is 1k with a 1uf bypass. How low can i go on the plate resistor? i tried larger cathode resistors but they tend to cause it to sound a tad dead by the time i try one large enough to kill the buzz.
so i'd really like to know how to tell when a preamp tube's bias is withing ok specs, plus whats the difference in effect of changing cathode resistors to reduce gain as opposed to changing plate resistors to do the same?
