How many dB are needed?
  • How many dB are needed?
    What is the range of voltage gain needed for a "typical passive " guitar signal to adequately drive the grids of a set of 6L6 power tubes in push-pull configuration.
    Depending on the class of power tube operation and the actual bias of the power tubes... usually somewhere between 25vac to 60vac from grid to ground.
    So do the math and start with 100mv of signal to the first stage and end up with 25vac to 60vac ... MATH
    I forgot to mention +6dB is twice the voltage gain.
    Last edited by Bruce / Mission Amps; 03-18-2008, 04:14 AM. Reason: forgot to add help
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
      I did the math
      I get about 48-56 dB
      Thanks.
