Problems with gain in my circuit
  • Problems with gain in my circuit
    I've nearly finished designing my bass pre-amp & overdrive :-) The pre-amp has bass, mid and treble controls. Then there's a switch for you to choose between two overdrive stages where the signal is driven through 12AX7 thermionic valves.
    The only problem I have with the whole circuit atm is the variation in amplitude I get from the various stages. The pre-amp section attenuates the signal by 16dB, the soft-overdrive adds 40dB and the MXR-overdrive attenuates the signal by 143dB!
    What's the best way to solve this problem??
    Not sure what I am looking at, but it appears the outputs of U1, U2 are feeding into the OUTPUTs of the XBP things. SHouldn't that be to their INPUTs?
      Looks like a simulation problem to me. (sure it was 143dB, not 144? :P) We can't really help until you try building it for real and come back to us with some physical problems. A bunch of extra volume controls is what you would use to equalize the differences between stages.
        In the second figure the top opamp is powered from dual supply but it still references its input to 4.5 volts (through R4).
        Third figure: The Opamp configuration is kind of odd. First of all, diode clipping won’t work well in non-inverting configuration. Does it have a reference to zero volts in the non-inverting input?
