Hey all... was thinking about power supplies and uses for the JJ 40+20+20+20 cap can and wondered what would happen if you put another electrolytic cap in series with the can (i.e. off the ground of the can).
Normally capacitance would change (halved if the caps had the same value) and voltage handling would increase (doulbe if the same value), right?
Since the JJ can should be able to handle all of the voltage on its own, I'm guessing this should work voltage-wise. (Or would it fry?)
But something's making me think the charge stored would change (or could that one cap really effect the capacitance of the four it's in series with normally?).
This is theoretical as I don't have the JJ can in front of me to test it out. But I was thinking this would be a way to try out different levels of filtering by changing just one cap...
(Please forgive me if the answer is obvious, I'm kind of new to all of this...)
