heaters
  • heaters
    why dont PCB heater traces cause hum when they are straight but wire needs to be twisted?
    Have you ever tried twisting PCB tracks? It's not easy. So designers have to just accept that heater traces on PCBs will radiate more magnetic field than twisted wires in a P2P amp do, and move sensitive stuff on the PCB further away if it turns out to be a problem in prototypes.
