series heaters for 12ax7 preamp 24vac
  • series heaters for 12ax7 preamp 24vac
    somehow I just cant picture how to wire this?
    I had this idea to use some surplus transformers
    for small preamp things with 2x 12ax7
    Does this make sense to do ?
    run the 12V heaters in series to use the 24v winding
    so pins 4 and 5 only right?
    I am used to wiring them up for 6.3volts
    and then I had working a doubler/tripler scheme for the
    other winding..
    not saving a whole lot of coin I know but
    I have like 10 of these things..
    Steve
    other winding..
    Steve
    You mean you want to wire them up like this?......
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
      looks good to me
      I think I will give it a go...
        One noise-reduction suggestion - you should probably ground one of the 24VAC leads and wire the tube with the earliest triodes to the grounded side.
        (did that makes sense?)
          I think so..
          you mean the first and second stage if I cascade them?
          I imagine I could also do a false centertap and ground that?
          then again this "aint" 6.3v any more..
          Steve
            A false CT good for 150mA? I dunno. (by which I mean that I do not know, not that I'm dubious of the idea)
            First and second stages, yes, that's what I meant.
            Hope this helps!
              Check out Peavey Classis 50 schematic. The preamp tubes there are wired this way.
