What's different in a push-pull amp? I'm assuming the preamp and power amp stages work the same way -- resistors here, caps there, and signal. It can't be that different...
My best guess, going on absolutely nothing, is somewhere there's a circuit that somehow splits the upper part of the incoming signal with the lower part and sends them off. I don't know how to do this; maybe run the signal to two imbalanced triodes? A 12AX7 dual triode with one triode biased way low (so it overdrives the entire bottom half of the wave to flat) and one biased way too high (so it overdrives the entire top half of the wave to flat)?
Does that set the mid point too so that the center of the (now deformed) output wave is where the would-be center of the input wave should land a properly amplified wave? If so I can send that to two amps and mix their outputs...
