I'm new here but based on what I've read this seems to be the best place to find an answer to my question... I have built a nice little 12V solid state stereo power amp based on a tripath chip (www.41hz.com look for the AMP6-Basic). This amp is designed to accept a 1V line-level input. The inputs can take up to about a 4V swing. I am converting this into a small guitar amp head for a friend and would like to build a tube preamp for it.
Here's the rub... I'm worried about giving up a lot of volume from the amp by using the following design (one per channel) http://www.beavisaudio.com/Projects/...alveCaster.gif
I will run that ciruit at 12V also.
Other than swapping out the volume pot for something smaller (50K or so) is there anything else I should do to make sure I'm not giving up valuable gain from the preamp stage?
Any advice is much appreciated.
