In all the info on the net regarding biasing output tubes and don't believe
I've seen mentioned how to bias a tube if it class A and fixed bias. The
recommendation for push-pull is 70% of max dissipation. For class A it's
90%, but this presumes cathode bias which will limit the increase in
dissipation.
My amp is single-ended with parallel 6v6s with fixed bias. I've been biasing
the tubes to 10w dissipation (27ma for 384 plate voltage) which sounds fine
but if I play a bunch of strong full chords on my guitar the current goes up
to about 45ma or so. I suppose the plate voltage drops a bit at this point
though I haven't measured it. If not, the dissipation would be around 17w
which is more than the rating for the tubes.
Could I be stressing my output tubes too much ? I don't want to have to
think about what's happening to them while I'm playing.
Paul P
dissipation.
Paul P
