I can't believe how fortunate I was to have stumbled onto this thread - I was at that perilous juncture of thinking I knew what I was about, but being totally off base!
Biasing SE class A, fixed bias
I’m not sure if it’s a good idea to connect the power tube screen to the preamp supply. The increase in screen current will drop the preamp voltage right down when the amp is at full power and it’s only 200V now. Perhaps it would be better to use a separate RC filter from the choke for the screen or a MOSFET series regulator?
You want Class A Single End, Fixed Bias but Va is a bit high - right?
Perfect scenario for "Back Biasing", with this scheme the bias voltage effectively is subtracted from the B+ so that the tube sees Anode to Cathode Voltage (and screen to cathode) much the same as when cathode biasing.
Could draw up the scheme but why bother when its been already done and explained so nicely.
Back Biasing
Cheers,
Ian
