i'm about ready to order parts for a 4x6v6 build with a cascaded pre like i did with my 18 watt. The schematic is a 36 watt with el84's from 18watt.com that i edited my pre onto and changed the pin #'s on the power tubes to reflect 6V6's. I modded my 18 to use 6v6 and really liked it, so i wanted to do the same by building the 36 watter but changing a few things to work with 6v6 outputs. So the schematic has PA values that are for el84's because i haven;t changed those not knowing what to use. i hilighted components who's values i either definatly need to be changed like the cathode resistors and screen resistors, and some that probably should but i'm not sure. If i only had 2 questions that could be answered it would be what screen and cathode resistors should i use, and should i use one of each per pair like on the schematic. Also, most 6v6 amps seem to use 1.5 grid blockers. should i use the same or stick with the 8.2k's on the schematic?
To give you an idea of what i'm shooting for, i want a fairly high gain (yes, i know it's REAL high, but the pre drawing is just an unfinished general idea) pre with a lot of headroom in the PA. The tone i want should have a squishy feel, sound very complex, and sound closest to a marshall tone. JCM's have always been my fav. I definatly want to stay away from that real hard/stiff feeling attack.
So if you could tell me what values i need or probably should use it would help me get the parts on order finally. Theres one R at the beginning of the B+ referencing ground with a question mark, and i'd like to know whether it's necassary and what it even does. Don't bother with the pre, as thats just a basic skeleton that will likely be change and possibly a lot. (possible one less stage and V1 paralleled) the PT will be a hammond 270HX and the OT is a 4k 40 watt heyboer. aside for the 1st most important question as to the cathode and screen values, anything you notice that might seem funky please critique. I'm flying 1/2 blind here. I know this is a lot to ask, but i have to try and figure out what to order so please give me any advice you can. (aside from "give it up" that is ) Heres the schematic, thanks....
http://img518.imageshack.us/my.php?image=6v6aj1.jpg
