Hello,
I have a little amp which started out as a tweed champ, then became a 5E2 Princeton and now is basically kind of a Matchless Spitfire w/ a 6V6 - it is starting to impress me...
My question now is where else I can take it. It was built from a dual 6V6 Motorola record player (so I feel I'll have no issue with running a single El34 or KT66 as far as current draw is concerned.
I'm using a SE Heyboer OT (that is a beefed up Champ OT w/ 8 ohm and 16 ohm taps) into an 8 ohm load. My plate voltage with a 5Y3 is 340 vdc, my cathode resistor is 470 ohm, my power supply caps are all 450v rated.
I'm interested in trying this out with an EL34 and a KT66.
My questions follow:
A) am I correct that to use either an EL34 or a KT66 (or, for that matter, dual parallel 6V6s), that I should use the 16 ohm tap?
B) what should my cathode bias resistor be for either of these tubes?
I have a KT66 and I've tried it with the existing bias (into the 8 ohm tap) and it sounds really good - but I was surprised as I expected it to be biased poorly and that it would sound pretty crappy.
Thanks in advance for any guideance
