Hello,
I'm finishing up recapping a Music Man amp (#2475-130) that runs on 6CA7 (EL34) tubes. I noticed that this amp has something different and interesting in the output circuit. There are JE1692 npn-type transistors on the output tube cathodes. One per pair (2) and the collector is connected to cathode/emitter through 3.9ohm resistor to ground. What is this? Some sort of self-biasing arrangement? Should I replace these w/ new? Also how about the LM1458 dual op-amp... should this be replaced, and what role does the op-amp play?
