I've been thinking about this for a while, and the concept is starting to take its final shape.
The amp will have a typical 5F6A/Plexi preamp with a 2X6L6 power amp.
However, I want to also have a SE 1XEL84 power amp with cathode bias!
I want to have the 6L6 on a switch so I can turn them off and use it in 5W mode at home. However, the EL84 output will also be tapped off and reinjected before the 6L6's PI (paralleled to the regular preamp signal, with a mix control).
Also the EL84 will have a switchable internal dummy load, so I can use just the 6L6 power amp if I have a single cabinet (yet still be able to inject the EL84's crunch into it), or use 2 cabs if I so desire.
Anyway, it's all taking form, but one problem I have is I can't run the EL84 on the same B+ line as the 6L6. I want high voltage for the preamp and 6L6, like around 450V, but that's gotta drop to like 300V for the EL84.
Any simple way of doing that, short of having a 2nd PT?
Also, if I run the preamp and 6L6 on the same power rail, will switching the 6L6 off send the B+ voltage through the roof because of the load removed? I know Mesa amps simply lift the ground from the unused power tubes and it doesn't seem to cause them any problems.
