Hi ive got a SE 5w amp using a 12ax7 and an EL84. It has always had rather harsh quite unpleasant overdrive with power valve OD, im playing around with the plate voltage. Am i right in thinking lowering the plate voltage of the el84 will smooth out the overdrive?
The original reading from ground to pin 7 of el84 (this is plate voltage right?)
was around 330v.
Ive managed to get this to around 270v and the od is now a bit smoother.
I read on ampmaker on setting up the 5w SE amp (similar to mine) that it should be 245v
cheers
was around 330v.
cheers
