HI Daz
I've just been through this with my 2nd build (a push-pull tweed). MWJB and Bruce from Mission amps were (as usual) extremely helpful to go out of their way to reassure me that its okay to run the tubes at higher dissipation. I'm using the new sensor "Tung-Sol 6V6GT" re-issues, and have the amp set up with switchable fixed or cathode bias.
On fixed bias I get 368VDC on the Plates, 364VDC on the screens and have the tubes biased at 28mA (measured using the 1R cthode resistor method - so there's a little bit of screen current in the equation) giving 10.5W per tube
On cathode bias I have a 330R (measures at 327R with each 1R cathode resistor) and the plates are 355-356, screens are 357-358 and the cathode is 24V, giving 36mA per tube and 12W.
They do sound a lot better, and I'm not getting any red plates yet
