i try to avoid any tone shaping components in the audio signal path. i like to add a passive filter section into the negative feedback line. to alter the frequency response via phase cancelation seems to be a very musical sounding one. i do it all the time with my recording gear.
i heard this was done before.
i need a filter with a 3db/oct shelf boost at 90hz, 2.3db band-cut at 330hz with a very wide band so that the response curve gets flat again at around 2.4khz. the outcome should be a decrease in the bass response below 90hz and a low-mid boost centered at 330hz.
my amp has a 2 and 4 ohm OT and the NF is connected to the 4 ohm tab. could i avoid the business of an make-up amplifier for the NF signal, because of the attenuation caused by the passive filter i like to add, by adding a second OT connected in reverse to the speaker output (4 ohm and ground of 2nd winding of the existing OT to 4 ohm and ground of 2nd winding of extra OT) and use the 8 ohm tab of the extra OT as the double of the NF signal? of course i will secure the leads of the primary winding of the extra OT.
nick.
nick.
